Discussion topic: Setting up a replacement sky q box
Message posted on 07 May 2025 02:52 PM
I am disabled, therefore I will need an engineer to set up a replacement sky q box. Is this possible?
Message posted on 07 May 2025 03:15 PM
Re: Setting up a replacement sky q box
Yes, go ahead and call Sky to arrange it.
Message posted on 07 May 2025 03:17 PM
Thanks, do you have a phone number to call sky to do this, please?
Message posted on 07 May 2025 03:23 PM
@NellyMGTF
To call Sky dial 150 (free) from either a Sky Talk landline or a Sky mobile. Alternatively use this link…
https://www.sky.com/help/home
UK customers: Scroll down and click on ‘Need more help’ leading to a number starting 0333.
ROI customers: change the flag in the bottom right corner of the link to the ROI flag then scroll down and click on ‘Need more help’ to see a dedicated ROI number. (Customer Services in the ROI are not open at weekends).
The forum filters don’t allow the posting of full phone numbers on here.
Calls to Sky will initially be automated which may try to send you here to the forum, offer you online help or offer to send you a text. Stay on the line as long as possible and saying nothing when asked the reason for the call sometimes helps being put in the queue for an agent.
Message posted on 07 May 2025 03:24 PM
Also, see here: https://skyaccessibility.sky/
Message posted on 07 May 2025 03:41 PM
Thanks folks, engineer coming tomorrow.
