5
This discussion topic has been answered Discussion topic: Second Uhd box?
This message was authored by: Anth+worton
Second Uhd box?
are sky planning on introducing the use of a second uhd box in the home or do I have to live providers to get this service?
This message was authored by: Dallen9798 Answer
Re: Second Uhd box?
@Anth+worton
The Q system will never get upgraded to support UHD on the minis as the whole boxes will need changed.
I'm pretty sure the Sky Stream / Glass pucks support UHD?
My views are my own and I will assist where possible.
Sky Q 2TB UHD, 2X Mini Box, Sky BB UF1, Booster 4
I am just a customer, If I've got something wrong feel free to tell me, If I've something right mark it as an answer
Re: Second Uhd box?
@Anth+worton
Re: Second Uhd box?
@Anth+worton  As per @Dallen9798  reply the mini's are unlikley to ever be updated, for UHD in each room you'd need Sky Stream where all the stream puck support UHD, however as these are not using a satellite signal you'd need decent broadband speeds as the below table shows.
Package:   minimum broadband speeds:
HD   25Mbps
HD + 1 puck or additional Glass TV   30Mbps
UHD   30Mbps
UHD + 1 puck or additional Glass TV   35Mbps
Avatar for Anth+worton
Re: Second Uhd box?
I currently have the Sky Q 2TB UHD, 3x Mini Box, but I've upgraded 2 other TVs in my home and it's annoying I can only watch hd on them when they support uhd. I hear virgin can support upto 2 uhd boxes. I can't understand why sky can't do the same
Re: Second Uhd box?
@Anth+worton  VM boxes are newer and use a different system entirely to Sky Q.
Re: Second Uhd box?
They could but I doubt they'll invest in upgraded Q hardware - for multiple UHD the route is now glass/stream.  (But no recording)
