This discussion topic has been answered Discussion topic: Second Uhd box?
Message posted on 29 Apr 2023 08:57 AM
are sky planning on introducing the use of a second uhd box in the home or do I have to live providers to get this service?
Message posted on 29 Apr 2023 09:01 AM
The Q system will never get upgraded to support UHD on the minis as the whole boxes will need changed.
I'm pretty sure the Sky Stream / Glass pucks support UHD?
My views are my own and I will assist where possible.
Sky Q 2TB UHD, 2X Mini Box, Sky BB UF1, Booster 4
I am just a customer, If I've got something wrong feel free to tell me, If I've something right mark it as an answer
Message posted on 29 Apr 2023 09:04 AM
Re: Second Uhd box?
@Anth+worton As per @Dallen9798 reply the mini's are unlikley to ever be updated, for UHD in each room you'd need Sky Stream where all the stream puck support UHD, however as these are not using a satellite signal you'd need decent broadband speeds as the below table shows.
Package: | minimum broadband speeds: | |
HD | 25Mbps | |
HD + 1 puck or additional Glass TV | 30Mbps | |
UHD | 30Mbps | |
UHD + 1 puck or additional Glass TV | 35Mbps |
Message posted on 29 Apr 2023 09:05 AM
Re: Second Uhd box?
I currently have the Sky Q 2TB UHD, 3x Mini Box, but I've upgraded 2 other TVs in my home and it's annoying I can only watch hd on them when they support uhd. I hear virgin can support upto 2 uhd boxes. I can't understand why sky can't do the same
Message posted on 29 Apr 2023 09:07 AM
Re: Second Uhd box?
@Anth+worton VM boxes are newer and use a different system entirely to Sky Q.
Message posted on 29 Apr 2023 10:10 AM
Re: Second Uhd box?
@Anth+worton wrote:I can't understand why sky can't do the same
They could but I doubt they'll invest in upgraded Q hardware - for multiple UHD the route is now glass/stream. (But no recording)
