Discussion topic: Screen does not support HDCP - HELP
Message posted on 15 Jan 2025 10:24 AM
Re: Screen does not support HDCP - HELP
@Chodley wrote:What do you believe the handshake actually does?
The only part the cable plays in it, by the way, is carrying voltages representing either 1s or 0s along its wires at an extremely high switching rate. You know this from your course so I don't mean to be patronising. It does need to be high enough quality to do that reliably because there is no - well, very little - opportunity for error correction, unlike (for example) ethernet. I agree a poor quality cable can affect the signal. But if it deteriorates to the point a 1 can no longer be reliably distinguished from a 0, you lose the image. It doesn't "not look as good". You see the same effect in satellite transmissions in bad weather. Very rapid loss of coherent image followed by "no signal".
This is a good thread on the same subject https://forum.videohelp.com/threads/394232-does-HDMI-have-Error-Correction
You'd think it was a simple on off scenario, thus a faulty cable will either pass a signal or not but in my experience of dealing with various forms of media displays in practice it isn't that simple. I've seen screen corruption and colour distortion all caused by either faulty cables or low grade versions.
@SussexWolf is not alone in stating a improved PQ resulted from fitting a better quality cable either but whether this is a placebo effect or not I've an open mind on.
Message posted on 15 Jan 2025 12:44 PM - last edited: 15 Jan 2025 12:53 PM
Oh absolutely but I consider those failure states where the image is very obviously corrupted. Same with the sparkles you can get as described in that linked thread.
The subtleties of analog transmission were much finer grained and higher grade / better shielded cables in those days could absolutely produce a better picture for the same input while the poorer cable would still give an acceptable result.
The main issue with digital is a single bit being wrong (a subtle defect which would have been unnoticeable on analog) can be either trivial (red=127 instead of 126) or very significant (red=528 instead of 26) and that's a simplistic example of how reliant a single pixel is on signal timing / clean voltage switching - encryption makes it even worse.
Message posted on 15 Jan 2025 01:02 PM
I'm also open minded on the improvement in screen quality, but as I commented, my wife didn't know I'd changed the cable and unprompted made an observation on it.
What I can't dismiss though, is the reliability of the connection after switching to a new HDMI 2.1 cable. The old Sky cable worked fine with my Sky Q box and older Sony 4K tv. But with the same Sky Q and cable and a new LG C4 tv, within days I was finding the tv would no longer display the Sky Q HDMI input. The tv switched on, and switched to the HDMi input, but saw no signal. Unplugged and replugged the cable, no joy. Tried a different HDMI port on the tv. Manually switched inputs on the tv. The problem remained. Reboot the Sky Q box, and all works again until next time the Sky Q box is switched off, after which the problem returned. Tried two other HDMI cables I had, and the problem remained. Bought a new HDMI 2.1 certified cable for £7 from Amazon and the problem has gone.
Message posted on 15 Jan 2025 01:49 PM - last edited: 15 Jan 2025 01:50 PM
Our main objection is to the £70 / £700 / £7000* cables
*Forgive the slight exageration: it's actually only a bit over £5000 ; )
Message posted on 15 Jan 2025 01:55 PM
Wow. Now that's an expensive cable!
I'm not into expensive cables for something as simple as a connection between Sky Q and a TV. Just something which works reliably. This one did the job for me. I'm confident any number of similarly spec'ed and priced cables would work just the same.
Message posted on 15 Jan 2025 02:24 PM
They should face criminal charges for that pricing 😆
Message posted on 15 Jan 2025 02:56 PM - last edited: 15 Jan 2025 02:57 PM
" Nordost’s proprietary Micro Mono-Filament technology is then implemented, permitting the current and voltage to travel above the conductor’s surface, virtually unimpeded by insulation "
Got to admit, that's quite ingenious. Not entirely sure about the physics, though...
Message posted on 03 Feb 2025 08:19 PM
Just had the same problem and came across this page in my search for a fix.
Sky Q box connected to an LG 4k TV (only 2 years old) and connected to it for that whole period and working.
Unplugging the Sky box and the Tv for a few minutes has fixed it, for now at least. Unplugging the box alone didn't do it.
Message posted on 03 Feb 2025 10:18 PM
I'd recommend the cheap HDMI cable I linked in a prior post. It's fixed my connection issues with my Sky Q and new LG C4 tv.
Message posted on 10 Feb 2025 01:31 PM
This worked for me too! Thank you!
Message posted on 10 Feb 2025 01:35 PM
Message posted on 15 Mar 2025 09:10 PM
Hi Mjginwales. Thank you so much for your advice . I had folllowed previous advice from others and I even changed the hdmi cables . The only thing which worked immediately was totally unplugging my tv and switching back on again .
I am very relieved 😌. Hi from Dublin and as it's paddy's wknend this weekend, I wish you lots of Irish good luck ☘️ .
Message posted on 30 Mar 2025 11:41 AM
This happened to me this week 2 days running. Turned off at mains few minutes then back on sorted for now.
