29 May 2023 07:46 PM
Since Friday my satellite signal has been bouncing around. Friday and Sat I had "satellite signal" error message all day. I rebooted, unplugged SKYQ box serveral times but the same. error Yesterday i switched it on and got some sort of "signal" as I could see channels but couldn't pull up the TV guide (spins with waiting for TV schedule). Picture blurry too. Past recordings are there but nothing new since it hasn't detected a signal. Restarted it again this morning and got the "no satellite signal " error again. Turned it on this evening and I have got "signal" again. Pictures are blurry. When I go to settings - status - satellite signal says "currently have limited or no satellite signal for your sky service". Satellite signal - unlocked, signal quality and strength 0 and LNB type - SCR. Any ideas? I tried ringing SKY and was still on hold 30 mins later.
Thank you LJ
30 May 2023 10:08 AM
Posted by a Superuser, not a Sky employee. Find out more@Madjacks007 When the Sky Multiple Development Unit (MDU) trained engineer initially installed your Sky Q receiver was your communal Integrated Reception System (IRS) installation already able to support Sky Q receivers, or did the Sky MDU engineer have to install a Unitron dCSS-422 Sky Q Plug-In adaptor in the central IRS distribution cabinet that serves your flat.
If your communal IRS installation already supported a Sky Q receiver without any modification by Sky then initially report your present problem to the landlord's agent responsible for organising the maintenance of your communal IRS installation.
If the Sky MDU trained engineer had to install a Unitron dCSS-422 Sky Q Plug-In adaptor then you will need to report your present reception problem to Sky and arrange for the attendance of a Sky MDU traineed engineer, who will be able to analyse whether you have a problem with your Sky Q receiver, a problem with the Sky Unitron dCSS-422 adaptor, or a problem with your landlord's communal IRS system.
Godfrey.
29 May 2023 07:53 PM
Posted by a Superuser, not a Sky employee. Find out moreHi @Madjacks007
Assume you are on a Communal dish if you have set LNB to SCR?
If on a personal dish LNB setting is Wideband
29 May 2023 07:55 PM
@oldfella correct but others are not having any issues.
29 May 2023 08:01 PM
Hi @Madjacks007
You could try a Reset Settings in the Q box hidden menu. You will have to reset the LNB to SCR and also reset your Remote.
29 May 2023 08:16 PM
@oldfella thanks for your suggestion - just tried it and unfortunately I now get on all options - to use this service you need a satellite signal.
29 May 2023 08:21 PM
Have you reset the LNB to ScR @Madjacks007
And then power cycled the Q box?
29 May 2023 08:22 PM
Yes - it was already set to that and I have power cycled the Q box.
29 May 2023 08:26 PM
hi @Madjacks007
If you carried out a Reset Settings then this will have reverted the LNB setting to Wideband.
It then needs changing back to SCR and then power cycling the box.
29 May 2023 08:28 PM
@oldfella just checked that after I sent my reply so I have set it SCR and box ir power cycling.
29 May 2023 08:40 PM
Still the same error - to use this service..... @oldfella
29 May 2023 08:43 PM
Hi @Madjacks007
Assume you have turned the Q box off and checked that the dish cable is correctly fitted and not loose.
29 May 2023 08:44 PM
@oldfella yes to both questions
Godfrey.
03 Jun 2023 05:53 PM
@Godfrey got the management company to sort it out. They got an engineer out who found a fault and they did their magic by changing an adapter in the cabinet. Thank you.
03 Mar 2025 09:01 AM
This is happening to me right now, sky are saying 10th April before they can send out a engineer. So basically I'm paying for a service I'm not getting!!! Absolute joke I need to wait 2 months! I will be cancelling my contract and going elsewhere! Would not recommend sky !
