Discussion topic: Satellite Dish
This message was authored by: Harley_rice
Satellite Dish
I'm not able to have a satellite dish on my property is there cant chance this product I listed still work with a SKY Q/SKY +HD Box I don't want a sky glass or a sky stream I wanna stick to the original.
Re: Satellite Dish
@Harley_rice
Your post is a little confusing but suffice to say a satellite dish is required for Sky Q and Sky+. They are delivered via the dish.
Avatar for Harley_rice
Level 0 icon
Re: Satellite Dish
Yes I recently moved houses and in my new property, it does not allow me to have a satellite dish would this Product
One For All SV9215 Flat Indoor TV Aerial.. Allow me To continue watching sky Q
Re: Satellite Dish
Hi @Harley_rice
Unfortunately SKY Q (& SKY HD) need a dish.
The only time you don't need one specifically on your apartment/house is if there is a Dish feeding a communal system (such as an apartment block or for  some housing schemes)
Re: Satellite Dish
@Harley_rice wrote:
would this Product
Afraid not @Harley_rice
Level 0 icon
Re: Satellite Dish
So there is no possible way off me getting SKY Q is there a indoor satellite dish that I can open a window and let it get the channels?
Re: Satellite Dish
no - Satellite signals are very weak & you need direct line of site of the Satellites
If they do not allow dishes on the property it might be worth enquiring whether they have provided a communal system for residents
Level 0 icon
Re: Satellite Dish
I could try could you send some links through eBay it's worth giving it a go you know.
Re: Satellite Dish
@Harley_rice
It will not work without a proper Sky supplied satellite dish or a communal dish supplied through your landlord or management company.
Re: Satellite Dish
Sorry a communal system is not device you can get from stores or ebay - it is a significant cost of cabling and electronics - normally used for apartment blocks providing feeds to each apartment, but occasionally for some modern housing estates
Re: Satellite Dish
@Harley_rice  You seem to be intent on ignoring the advice provided.  You need a dish located outside the property, it will not & can not work indoors.
Re: Satellite Dish
@Harley_rice
'Portable' satellite television dishes do exist for situations such as mobile homes, but are essentially entirely impractical for domestic use, particularly indoors where the likelihood is there's no line-of-sight to the broadcast satellite orbital location anyway.
Any 'aerial' you see advertised is for digital terrestrial television ('Freeview') broadcasting from a local mast and absolutely cannot be used to receive Sky.
