5
This discussion topic has been answered Discussion topic: Satellite Dish Scaffolding
This message was authored by: Nicholas+Rope
Due to some repair work that needed to be done. Some scaffolding was put up and block my signal.
It has been removed but the scaffolding has been put up next door to fix their issues. Again I believe it's blocking my signal but it's not as severe as before
Granted I'm not an expert on this but I'm thinking that an Engineer can move my dish, so it's out of the way of the Scaffold or do whatever that is needed so I can get a signal to my TV because I'm thinking that the dish has to be in one specific location.
Am I correct?
Thank you
This message was authored by: Mark39 Answer
Re: Satellite Dish Scaffolding
@Nicholas+Rope providing there's a direct line of sight between the new dish .location and the orbiting satellite, yes.
Avatar for Nicholas+Rope
Level 2 icon
Thank you, appreciate it
Level 2 icon
After taking a look, it appears that a couple of inches from the side is being blocked, so I thinking that it may have been nudged
@Nicholas+Rope quite possibly.  An engineer can re-align it for you.
Level 2 icon
Thank you
