Discussion topic: Samsung Frame
This message was authored by Ellida This message was authored by: Ellida
Samsung Frame
We are having intermittent issues with the connection between our Sky Q box and our Samsung Frame TV. It appears to lose the picture, it sort of blips out. It happens irregularly and can be worse on some days than others. Thank you in advance for any ideas! Seriously considering binning Sky as the TV works perfectly when using Apps!
This message was authored by PandJ2020 This message was authored by: PandJ2020
Re: Samsung Frame
HDMI lead is mostly likely issue.
How long is it?  Check its pushed in fully?  Tried a different one?
I am just another Sky customer and my views are my own
Ellida
Re: Samsung Frame
Thank you - we've tried that and unfortunately it made no difference
This message was authored by Chodley This message was authored by: Chodley
Re: Samsung Frame
What happens if, just as a test, you run the Q box at 1080p?
Ellida
Re: Samsung Frame
And how do we do that please?
This message was authored by Laing1 This message was authored by: Laing1
Re: Samsung Frame
@Ellida press the home button on the remote scroll down to setting > setup> audio /visual > picture resolution and set it to 1080p
