Discussion topic: No satellite signal
Message posted on 21 Nov 2024 11:03 PM
No satellite signal
Watching tv tonight amd all of a sudden, screen goes blank, now no satellite signal message on all channels and reset hasn't helped. Went onto sky app to troubleshoot and it says the signal is fine, clearly not correct! help please?
Message posted on 22 Nov 2024 05:01 AM
Re: No satellite signal
@SandraMDuncan
Have you had bad weather? This can happen when snow settles on the LNB on your dish.
If not, check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Otherwise it’s likely to be a dish alignment issue so check the troubleshooting in this link
If you are connected to a communal dish you need to liaise with your building management company / landlord who will have their approved engineers to contact.
Remember, a misalignment is not necessarily something that will be visible to the naked eye and could only affect one or two channels.
