Discussion topic: Samsung Frame
This message was authored by: Ellida
Samsung Frame
We are having intermittent issues with the connection between our Sky Q box and our Samsung Frame TV. It appears to lose the picture, it sort of blips out. It happens irregularly and can be worse on some days than others. Thank you in advance for any ideas! Seriously considering binning Sky as the TV works perfectly when using Apps!
Re: Samsung Frame
HDMI lead is mostly likely issue.
How long is it?  Check its pushed in fully?  Tried a different one?
Avatar for Ellida
Re: Samsung Frame
Thank you - we've tried that and unfortunately it made no difference
Re: Samsung Frame
What happens if, just as a test, you run the Q box at 1080p?
Avatar for Ellida
Re: Samsung Frame
And how do we do that please?
Re: Samsung Frame
@Ellida press the home button on the remote scroll down to setting > setup> audio /visual > picture resolution and set it to 1080p
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Avatar for Ellida
Re: Samsung Frame
Thank you- will try that!
