Discussion topic: SKy Q change from 1TB to 2TB box
Message posted on 04 Mar 2024 11:42 AM
Re: SKy Q change from 1TB to 2TB box
Ok thank you.
would I just need to call them to try get a newer box?
I want a 2nd mini at the same time, they sent me one as part of me returning and taking out multi room. No point getting a 2nd mini if I can't use them both at the same time.
Message posted on 04 Mar 2024 11:51 AM
Yes: they'll probably want to charge a fee, so I'd suggest you negotiate based on the age of that hardware, its lack of HDR support and your intended Mini use.
Message posted on 04 Mar 2024 11:54 AM
Thank you
Message posted on 11 May 2024 12:54 AM
I've just checked and our hardware version is none of these it says 32DOAD What does that mean?
Message posted on 11 May 2024 04:24 AM
32Dxx is the mini box.
Message posted on 11 May 2024 09:18 AM
I edited the table to remove the Mini, as that wasn't the subject of the original post.
Message posted on 23 Nov 2024 12:18 PM
I found Timmy's reply about disc size very helpful. My hardware version is 32B206, but the table shows that it could be 1TB or 2TB with an asterisk at the end. I wasn't sure what the asterisk refers to so still not sure what size my disc is. Could anybody enlighten me?
Message posted on 23 Nov 2024 12:58 PM
@DaiapGymru wrote:I found Timmy's reply about disc size very helpful. My hardware version is 32B206, but the table shows that it could be 1TB or 2TB with an asterisk at the end. I wasn't sure what the asterisk refers to so still not sure what size my disc is. Could anybody enlighten me?
Hi @DaiapGymru The following link explains, including how to find if you have a 1TB or 2TB box.
Message posted on 23 Nov 2024 03:40 PM
Got it thanks MQ, it's a 1TB box. Who'd have thought you'd find this under the music section?!
thanks for your help.
Message posted on 14 May 2025 09:13 AM
I had the same so I called them yesterday 13/5 and there is a deal atm for a free 2tb sky q box.
Message posted on 01 Jun 2025 01:11 PM
Did you seriously get a free 2TB box 2 weeks ago? I've just called them to try and get them to upgrade my ancient 1st gen 1tb box which I should never have received last August in my opinion. And they want £99. No offers. No discussion. I'm fuming.
Message posted on 01 Jun 2025 01:49 PM
Yes I did, I called with a query which resulted in needing a 2tb Q box, the agent did a search and found a deal with a free box.
Message posted on 01 Jun 2025 01:55 PM
Wow. Ok. I may need to ring them back and try my luck again before I lodge a complaint.
What was the query resulting in you needing a 2TB box if I might ask?
Message posted on 01 Jun 2025 02:17 PM
@BazzerSW wrote:... before I lodge a complaint.
I can't really see the basis of a complaint.
Message posted on 01 Jun 2025 02:51 PM
You don't have enough information from what I've given about my situation to form an opinion. Bit that's fine. It's obviously not that someone got an offer 2 weeks ago why can't I have it. Bit more to it than that.
