Discussion topic: SKY Q PICTURE QUALITY
Message posted on 29 Feb 2024 01:41 PM
Hi, Satellite picture quality on our LG
Tv is not great and far inferior to the Sky Netflix feed on the same TV (picture quality is also better on 15
Year old small Samsung upstairs on multi room). We are thinking of changing the TV as I have tried all settings but just wondered if it was
Worth trying a decent Hdmi cable rather than the one Sky supplied.
I can see contradictory information
With regard to this on previous posts.
Any advice appreciated
Message posted on 29 Feb 2024 01:44 PM
Re: SKY Q PICTURE QUALITY
Hi @stevetugby
Unlikely to be due to HDMI lead. As they are digital signals HDMI cables either work or show nothing.
Message posted on 29 Feb 2024 01:47 PM - last edited: 29 Feb 2024 01:53 PM
It's not a 'Sky Netflix feed': it's just Netflix.
Netflix Premium over decent internet bandwidth could certainly be 'better' quality than a satellite-delivered channel: for a start the Netflix material may well be native UHD with HDR, which almost no satellite content is.
Message posted on 29 Feb 2024 07:30 PM
Are you using SD, HD or UHD satellite content when you make the comparison with Netflix? SD will look terrible on any large screen. I assume the Samsung is smaller than the LG? What model is it?
There's no credible contradictory information on HDMI cables on here. Anyone who says it's worth upgrading them to improve picture quality is wrong / has been duped.
Message posted on 01 Mar 2024 10:09 AM
Lg is 42inch and Samsung is much smaller but sky q set to HD or uhd.
When sky engineer came he was surprised at the picture quality and tbh my freind with sky q and a Samsung gets an excellent picture so
I guess time for a new TV and no point
In changing the hdmi. Thanks for your help
Message posted on 01 Mar 2024 02:24 PM - last edited: 01 Mar 2024 02:28 PM
@stevetugby wrote:Lg is 42inch and Samsung is much smaller but sky q set to HD or uhd.
Yeah sounds like it. If you have the model number, could check its rep.
HD at 42" should look great.
Message posted on 06 Mar 2024 04:41 AM
Had same issues with new 65" lg c3 really poor quality and very disappointed 😞
Sky out and told me handshake issues and swap to sky stream...didn't help
Played with settings and found..
Go to any mode filmmaker is best Brightness Auto Dynamic Contrast OFF.
Gamma BT.1886 Video Range Auto.
Colour Gamut Auto Detect.
Turn all settings in clarity to OFF
And turn TrueMotion to User Seletion
I found turning De-Judder 4 and De-Blur to 0 sorted my issues also turn Smooth gradation to Low
Apply to all inputs
Worked for me hope this helps many 🙏 x
