Discussion topic: SKY Q Box loses connection every day
This message was authored by: Rappy
SKY Q box every day loses connection to the internet.  Other devices occasionally lose connection, but not as much.
As of today, after following all the usual instructions of rebooting the router and the Q box, I still have no connection.
Sky Service Checker is saying there is no faults.
Am unable to check Q box using Ethernet cable as engineers fitted router by front door, so need around 10 metres of cable to connect that way.
This has been going on for over a month, but first time that I have been unable to restore connection to the Q box.
Re: SKY Q Box loses connection every day
Hi @Rappy
Have you carried out a Network reset on the Q box to help your issue.
Highlight Status and then select Reset on the right hand side. Follow instructions to connect by WiFi to your router.
Avatar for Rappy
@oldfella
Yeah, it keeps saying unsuccesful connection
@Rappy wrote:
@oldfella
How are you trying to connect @Rappy ?
Avatar for Rappy
@oldfella
Standard Network Reset, using WPS button.
Can't connect any other way, router is too far from Q box for Ethernet Cable.
@Rappy wrote:
@oldfella
So you are Sky Broadband then @Rappy
Maybe worth asking Sky for a Q booster to position midway between your Main Q box and your Sky hub.
Edit.
Are you pressing the WPS button on the main Q box?
Avatar for Rappy
@oldfella
That's a good point, the instructions on the network reset never mentioned pressing the WPS on the Q box.
Have tried that now, and got half my connection back, still no connection to internet, now been over 2 hours today.
@Rappy wrote:
@oldfella
Hi @Rappy
It shouldn't be necessary to press the WPS on the main Q box as the Network reset should start the box WPS automatically.
However it can sometimes work if you press the WPS on the main box and then within 2 minutes the Q hub WPS.
Just make sure the WPS lights are flashing on both units .
Avatar for Rappy
@oldfella
Thought it had worked for a minute there, but then the connection dropped again.
@Rappy wrote:
@oldfella
Worth getting a Q WiFi booster @Rappy
Sky will supply these free of charge to aid Q connectivity
Avatar for Rappy
@oldfella
Yeah, unfortunately that doesn't help me at the moment,  and the only way to get one is by calling them, spent 10 minutes answering all their questions to get told that there is a 40 minute wait to speak to a human.
This message was authored by: Saad+H
Hi... I've been having 💯% the same problem.
Called helpline but after waiting for over 30 mins No response & line is disconnected.
