Discussion topic: My box wont work
This message was authored by: Conny
Message posted on 21 Jul 2023 08:51 PM
My box wont work
The light on the front of the box stays red and won't work
Find out more
Message posted on 21 Jul 2023 08:55 PM
Re: My box wont work
Hi @Conny
Have you tried pressing the Standby button (Amber led) on the front of the Q box.
If this turns the Q box on
Try completly resetting your Bluetooth remote.
Then make sure that you are pointing your remote at the Q box and press 1 & 3 together until the led flashes and follow onscreen instructions to re- pair.
