Discussion topic: No network connection
Message posted on 21 Jul 2023 08:12 PM
No network connection tried everything
O
Message posted on 21 Jul 2023 08:18 PM
Re: No network connection
O
Hi @Lin+lin
If this is your main Q box
Try a Network Reset found in Q box Home - Settings - Setup - Network.
Highlight Status and then select Reset on the right hand side. Follow instructions to connect by WiFi to your router.
