Discussion topic: Romote broken
This message was authored by: NataliaToner
Romote broken
Need a replacement
Re: Romote broken
@NataliaToner wrote:
Need a replacement
Hi @NataliaToner
Check the following link and it will lead to a form for a replacement remote.
https://www.sky.com/help/articles/lost-stolen-damaged-sky-q-equipment
In the meantime if you have an Apple device with Sky Go you can set up a virtual remote to control your Q boxes.
See following link.
https://helpforum.sky.com/t5/Sky-TV/Virtual-Sky-Q-Remote-Now-Available-on-Sky-Go/ba-p/4363637?
Re: Romote broken
@NataliaToner
After checking the basics, ie; fresh batteries, re-pairing etc if your Sky Q remote is definitely broken/faulty, if you follow this link it should allow you to do some more troubleshooting and then it’ll send you to a form to request a replacement (there is the possibility this is not available to customers in the ROI).
https://www.sky.com/help/articles/lost-stolen-damaged-sky-q-equipment#get-in-touch
It may be quicker to purchase a new remote from a retailer / larger supermarket. If you do that as well as the above you’ll have a spare.
In the meantime if you have an Apple device with Sky Go you can possibly set up a virtual remote to control your Sky Q box. See this link which may help
This message was authored by: Clareylou69
Re: Romote broken
My remote has broken in my main room and sky q too the sound is not working on either
Re: Romote broken
@Clareylou69
Then the advice in how to obtain a replacement applies to you too.
