2
This discussion topic has been answered Discussion topic: Mini sky q has stopped working
This message was authored by: Julie1210
My mini sky q box is stuck on a blue screen with a accessibility on sky q ? Can't get the remote to go on setting
This message was authored by: Laing1 Answer
Re: Mini sky q has stopped working
@Julie1210 try the following...
Unpair their Sky Q remote from the box by holding 4&6
Wait for the remote to flash you should then be able to dismiss the information screen by clicking on Skip & set up later
Hold 1&3 to repair the remote control
If 4&6 does not allow you to clear the information screen, try holding 7&9 to reset the Sky Q remote then hold 1&3 and follow the on-screen setup journey to allow the remote to control your TV.
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
This message was authored by: _Pipmcg-
That is amazing! Is worked and has been stuck like this for a week no matter what I did. Sally I still have another issue in that my main box is telling me I have no internet when I do but at least I can see live tv! Thank you
