Discussion topic: Reporting bugs
Message posted on 22 May 2024 02:54 PM
Reporting bugs
Where can I report Sky Q UI or useability bugs ? Sorry if there was already a discussion on this, I looked for ages and honestly couldn't find one.
Message posted on 22 May 2024 02:57 PM
Re: Reporting bugs
What's the 'bug'?
Message posted on 22 May 2024 03:20 PM
Re: Reporting bugs
I'm hoping I'm doing something stupid, rather than it being a bug. When I've finished watching a recording, I press the 'back up' button to stop it. Most of the time, this takes me back to the recordings list where I can delete what I've just watched. Sometimes though, pressing 'back up' takes me straight back to live TV. I have to then go back into recordings, find that recorded series again, find the episode again in order to delete it. I find this incredibly irritating, so I'm hoping you can tell me if I'm doing something wrong?
Message posted on 22 May 2024 03:25 PM
Re: Reporting bugs
I believe it's a known bug for some (others may confirm). Strangely doesn't occur for me.
Message posted on 22 May 2024 03:29 PM
Re: Reporting bugs
Thanks. It's not just me then. Hopefully they will fix it at some point.
Message posted on 22 May 2024 03:45 PM
Re: Reporting bugs
It's happened to me twice I think in 4 and 1/2 years of having Q.
Message posted on 22 May 2024 03:56 PM
Re: Reporting bugs
Hi @Jest1975 This is been happening for 8 years, so common that I don't even think about it. As Sky Q approaches end of life the chances of a fix must be very remote. If you want to report it, try an email to viewer relations, viewerR@sky.uk. However I suspect that you are wasting your time.
Message posted on 22 May 2024 06:05 PM
Re: Reporting bugs
hi @Jest1975
I echo @Jest1975 's observation. & also don't think about it any more.
It has been raised with SKY but I am not 100% sure they ever formally acknowledged it as a bug (just like the flakey behaviour of the Continue section & also sometimes flakey behaviour of the buttons above recordings )
I think there is virtually no chance of it now being fixed
