Discussion topic: Sky Q box freezing while watching apps - having to power down every day and re-set
Message posted on 22 May 2024 01:02 PM
Every day now whilst watching any App on sky Q main box, it freezes and have to power down to re-set - sky platform works fine, router still connects (sky broadband)
is it a hardware problem?
Message posted on 22 May 2024 03:52 PM
Re: Sky Q box freezing while watching apps - having to power down every day and re-set
Hi @SGH52
If you have Netflix on your Q box you can check the Broadband Speed that you Q box is receiving.
Open Netlix on your Q box and go to the left hand menu.
Select Get help near the bottom of the menu.
On the next screen there is an option to Check your network. Try this and see if you are getting a comparable speed to other devices.
Message posted on 22 May 2024 04:13 PM
Message posted on 22 May 2024 04:45 PM
