Discussion topic: Hand set does not work on mini box
Message posted on 22 May 2024 06:39 PM
Unable to turn on or control any functions with my mini box ,with my handsets unable to set up after loss of internet
Message posted on 22 May 2024 06:49 PM
Re: Hand set does not work on mini box
Hi @Andrew19911
First reboot the mini.
To reboot press Standby on your mini remote (if the box responds to the remote), and then switch off and unplug at the mains.
Wait at least 30 secs and then Plug back in and switch your mini box back on at the mains.
Wait for the on screen instructions to disappear and the front led to turn Amber. Then wait for 30 secs before you press Home on your mini remote or if this is not working press the standby button on the front of the mini box (Amber led).
If you still have issues With the mini box on with green led try completly resetting your mini Bluetooth remote.
Then make sure that you are pointing your remote at the mini box and press 1 & 3 together until the remote led flashes and follow onscreen instructions to re- pair.
