Discussion topic: Removing HD option
Message posted on 24 May 2025 06:44 PM
Removing HD option
Hi, we have Sky Q with Movies and HD options
Trying to save a little money, what happens if we remove HD option, do we then lose many channels?
What about movies, are they only HD so won't be able to watch any, or only a few Movie channels?
Thanks in advance.
Message posted on 24 May 2025 06:51 PM - last edited: 24 May 2025 06:52 PM
Re: Removing HD option
Thanks in advance.
Hi @Vince888
Sky Cinema (Movies) is in HD as standard on Q if you subscribe.
The Sky Q Sports pack and TNT Sport if you subscribe through Sky are also in HD as Standard.
Sky Signature includes BoxSets and Entertainment channels only in SD as standard.
Only free to air channels such as BBC, ITV etc are in HD. The Q HD pack is required for all other Sky Signature HD content, including Catch Up in HD, On Demand in HD and BoxSets in HD
If you do not have the Optional HD pack you need to change the Download to SD in All Formats (as HD is the default setting).
So that you do not need to do this every time it’s best to change your Download preference to SD in Home - Settings - Setup - Preferences.
This needs to be done on the main Q box.
Then if you want to download any HD content from free to air channels (BBCHD ,ITVHD etc) you can select HD in the All formats tab of the content . This will change the format for that particular download only but still leave your format to SD in preferences.
Message posted on 24 May 2025 07:27 PM
thanks for all that information.
I have the Cinema extra subscription, but are you saying I must pay the extra HD option to watch all the Cinema channels?
or can I watch them all in SD?
Message posted on 24 May 2025 07:29 PM
No @Vince888
Sky Cinema is in HD as standard as I said in my post. You do not need the HD add on to watch HD Sky Cinema.
Message posted on 25 May 2025 08:15 AM
Great, OK so can still watch Cinema. All Movie channels too?
Final part just to be clear, when removing the additional HD subscription do we lose any other channels, or can still watch all of them but just in SD?
Thanks in advance.
Message posted on 25 May 2025 08:43 AM
Final part just to be clear, when removing the additional HD subscription do we lose any other channels, or can still watch all of them but just in SD?Thanks in advance.
hi @Vince888
No you don't loose channels - as you say you just have access to the SD versions
As @oldfella you can watch any Free to Air (FTA) channels that are in HD (some of which like the BBC & ITV only have HD versions now)
One quirk is that you can watch & record Channel4 & C5 in HD but can only watch SD downloads without the HD add on
Message posted on 05 Jun 2025 12:29 PM
For sake of completeness, when I called Sky to change my current package and remove HD, they said I would no longer be able to watch any recordings or purchases that are in HD 😞 😟
Message posted on 05 Jun 2025 12:32 PM - last edited: 05 Jun 2025 12:35 PM
You can still watch any Purchases but not recordings for any Subscription HD channel
You can also watch FTA (Free to Air) channel HD recordings without the HD add on (although not C4 & Channel 5 HD downloads )
Message posted on 05 Jun 2025 03:26 PM
Think I'd cut down by 1 pint a month ahead of losing HD.
Message posted on 05 Jun 2025 03:55 PM
@oldfella wrote:
@Vince888 wrote:Hi, we have Sky Q with Movies and HD options
Thanks in advance.
Hi @Vince888
Just to add to @oldfella's comment.
In the UK, Sky Sports subscribers get both HD & SD channels (most Sky Sports SD channels have been delisted in the UK). My understanding is that TNT Sports and Premier Sports are separate subscriptions and get the HD and SD where available.
In Ireland, it's slightly different:
For Sky Sports, the HD pack is required for HD channels.
For TNT Sports and Premier Sports channels, one can get both HD and SD channels via the Sports Extra pack.
Just wanted to add this for future readers.
Disney+ • Paramount+ • HBO Max • Discovery+
