Discussion topic: Need a new remote control as the volume button has stopped working
This message was authored by: Humptydumpty2
A new Sky remote control is required asap
This message was authored by: Keeley7714
Remote
Could I please find out how to order a new sky q remote as ours has stopped working
Re: Remote
You can purchase a new one from various supermarkets, Amazon and Argos. Or, follow the instructions on here and Sky should send you a free replacement:
https://www.sky.com/help/articles/lost-stolen-damaged-sky-q-equipment
This message was authored by: Me134
Re: Need a new remote control as the volume button has stopped working
If you need it quickly your local Asda (others as well) usually stock them.
Before you do, try repairing with the box but do replace the batteries first.
https://www.sky.com/help/articles/sky-q-remote-help
Not a Sky employee
Sky Q with 2GB UHD box using WiFi
Sky FTTP 500Mb to Max Hub (WiFi disabled)
Pair of TP-Link Deco BE65's in AP mode used for WiFi access, main Deco hardwired to Max hub
2 Windows desktop PC's hardwired to each Deco, everything else using WiFi
@Humptydumpty2 @Keeley7714
Meanwhile, if you have an android or Apple device with Sky Go you can possibly set up a virtual remote to control your Sky Q box. See this link which may help
https://helpforum.sky.com/t5/Sky-TV/Virtual-Sky-Q-Remote-Now-Available-on-Sky-Go/ba-p/4363637?
