Discussion topic: Remote won’t change volume
This message was authored by: Leea66
My remote has stopped changing volume on my Samsung tv despite having done it for  past 3 years. Have tried the 7&9 and then 1&3 thing but it now says it doesn't support the tv. What can I do to sort it out?
Re: Remote won’t change volume
@Leea66 Have you tried rebooting your main Q box ie
switch it back on then follow the on screen instructions then repairing your remote
or if that doesn't
You could try resetting the settings in the Q boxes hidden menu.
To enter the hidden menu press the home button and scroll down to settings but do not select settings.
With settings highlighted press 0 0 1
Only Carry out the first Reset being Reset Settings as the others will wipe all recordings.
After the reset you will have to re-pair your remote assuming you are using a bluetooth remote by pressing 1 and 3 together on the remote
This message was authored by: lolllp
i've still had no luck with that
This message was authored by: Elaine2012
This issue has just come up for me, despite using mine for 3yrs also @Sky
This message was authored by: Nathan27
This is now happened to me aswell, did you manage to get a fix?
This message was authored by: GZT
Juat Re: Remote won’t change volume
I've suddenly got the same issue, did anyone find a solution? It happened after I had a warning that the remote batteries needed changed
I just persisted with turning everything off and reconnecting the remote to the tv, took about 30/45 minutes but it randomly connected
Thanks mate, I managed to get mine working again this morning after leaving it switched off for a while
I turned everything off and reset my remote to connect too, it didn't work the first two times but on the third it randomly connected with the first setting. Anyhow, works now!
This message was authored by: Russec
I'm having similar issues, sometime I can get the remote Volume working again for a couple of hours then it goes again. Strange think also when the volume will not work on Sky Q remote, I cannot turn the TV off with the TV remote - completely lost to understand what this is.
Any direction to resolve would be appreciated.
This message was authored by: Peterharry
I have the same problem - remote stops operating volume change and will not switch Samsung tv off. It will still change channels. Switching everything off at the socket and then on again cures the problem - but it comes back  - and the frequency seems to be increasing
This message was authored by: Loucas28
I'm also having the same problems with sky and tv remote. Nearly brought a new tv but after reading on here I can see it's a wide spread issue.
I have tried all the above and still volume buttons not working.
please help!
