Discussion topic: Reset not available
This message was authored by: Just+Wright
Reset not available
For about a week I have had to unplug and plug my Sky Q box to get any response from it.  Now it has died, saying the hard disk error. I have searched through community, and it seems that the only solution is to reset the hard drive.
However,  when trying to follow the instructions I get as far as 'Select Re-set' , but I don't have that option on the screen.  How do you do this?
Re: Reset not available
Hi @Just+Wright
Are you going into the main Q box hidden menu?
there are three Reset options
  1. Reset Settings
  2. Reset hard drive
  3. Factory reset
Avatar for Just+Wright
Thank you, Oldfella
  I am an old woman and of course I selected select because if I see a button I have to press it!
Seriously, this seems to have done the trick, and I don't seem to have lost any of my recordings!
@Just+Wright wrote:
Thank you, Oldfella
Hi @Just+Wright
If you haven't lost any recordings you must have done the Reset Settings.
Both Reset Hard drive & Factory reset will definitely wipe all recordings.
Main thing is that it has helped (whatever you did)
