2
This discussion topic has been answered Discussion topic: Box switching off if left on planner
This message was authored by: csc2ya
Our Sky Q box (1TB I believe), if left on the planner for an extended period (If we're about to watch something, and are getting drinks for example), will switch off completely, as if it's been rebooted. When turning it back on via the remote, it will go through the same startup sequence it would go through as if it had been switched off at the mains.
I'm wondering if this is normal behaviour, or if it's likely to be an issue with either the box itself, or the software.
Re: Box switching off if left on planner
Hi @csc2ya
Assuming the Software is up to date that's not a current issue.
https://www.sky.com/help/articles/sky-software-updates
Hi @csc2ya
Avatar for csc2ya
Checked the software last night, and it wasn't up to date. I've now updated it, and the issue no longer occurs.
Thanks for the help
