Discussion topic: Remote control
Message posted on 07 Jun 2025 12:11 PM
Remote control
My remote control won't work , I've replaced the batteries but it still won't work.
Message posted on 07 Jun 2025 12:14 PM
Re: Remote control
Remote control
Re: Remote control
@Kevin206
After checking the basics, ie; fresh batteries, re-pairing etc if your Sky Q remote is definitely broken/faulty, if you follow this link it should allow you to do some more troubleshooting and then it’ll send you to a form to request a replacement (I’m not sure if this is available to customers in the Republic of Ireland).
https://www.sky.com/help/articles/lost-stolen-damaged-sky-q-equipment#get-in-touch
It may be quicker to purchase a new remote from a retailer / larger supermarket. If you do that as well as the above you’ll have a spare.
In the meantime if you have an Apple device with Sky Go you can possibly set up a virtual remote to control your Sky Q box. See this link which may help
https://helpforum.sky.com/t5/Sky-TV/Virtual-Sky-Q-Remote-Now-Available-on-Sky-Go/ba-p/4363637?
Re: Remote control
@Kevin206 Try the troubleshooter here:
https://www.sky.com/help/articles/sky-q-remote-help
If that doesn't work you may need to order a replacement from Amazon.
Message posted on 07 Jun 2025 12:15 PM
Re: Remote control
Remote control won't work, replaced batteries but still is not working .
can I get a replacement?
Message posted on 07 Jun 2025 12:16 PM
Re: Remote control
@Anonymous
No need. Sky will replace.
Message posted on 07 Jun 2025 12:18 PM
Re: Remote control
Please read my earlier reply.
Message posted on 07 Jun 2025 12:19 PM
Re: Remote control
@Daniel0210 I forgot Sky did that for free with Q.
