Discussion topic: Remote control
Message posted on 04 Dec 2023 05:29 PM
Remote control
Remote control is not working
Message posted on 04 Dec 2023 05:42 PM
Re: Remote control
Hi @Brian25
First Try completly resetting your Bluetooth remote.
Failing this
Check the following link and it will lead to a form for a replacement remote.
https://www.sky.com/help/articles/lost-stolen-damaged-sky-q-equipment.
In the meantime if you have an Apple device with Sky Go you can set up a virtual remote to control your Q boxes.
See following link.
https://helpforum.sky.com/t5/Sky-TV/Virtual-Sky-Q-Remote-Now-Available-on-Sky-Go/ba-p/4363637?
