Discussion topic: Sky q not working
Message posted on 04 Dec 2023 07:07 PM
Sky q not working
Hi
my sky tv is not working, we have reset it and also followed instructions on the settings area. We have also switched it off and checked all wires are ok.
the message we have coming up is
it looks like you do not have internet connection right now.
we have tried everything just can't get it to work
Message posted on 04 Dec 2023 07:10 PM
Re: Sky q not working
@Debbiebaillie wrote:
Hi
Assume this is your main Q box.
Try a Network Reset found in Q box Home - Settings - Setup - Network.
Highlight Status and then select Reset on the right hand side. Follow instructions to connect by WiFi to your router.
