Discussion topic: Remote Setup Unsuccessful
This message was authored by: Everydisplayname
Remote will not pair. Repeated message "remote setup unsuccessful"   This is despite sky sending new remote. Pressed 7&9 then did 1&3 still get the same message.
Re: Remote Setup Unsuccessful
Hi @Everydisplayname
Make sure you are pointing the Remote at the Q box infrared sensor when you press 1 & 3 together.
This message was authored by: MrThompsonESQ
I received a replacement remote today and Connor pair?
I get the same result above?
working fine except volume control!
Doesn't work either!
So you can pair it but it doesn't control the volume? That doesn't sound like the same problem as the original post. Did it have your model of TV listed?
It controlled the sky Q box out of the box, but not the volume. In the past there has been a search my tv manufacturer?
I have now presses 7 & 9 on all other remotes that were connected to this to, have been though all steps and still new remote will not connect?
old remotes control sky but volume and speech commends no longer work!
this has stumped me!
When you do the 1 & 3 it should start the pairing process which includes the selection of TV model
Shouldn't need to touch any other remotes.
It doesn't, it just says set up failed?
I'm going to escalate this as I don't know what can go wrong in that process. The box is in line of sight and you're pointing the remote at it, as it uses IR for that I think?
Watch out for a blue chat bubble once Sky respond.
Yep. I even searched where the or sensor is to ensure it's pointed at the right place 🤓
This message was authored by: Mr+Flibbles+86
Thanks for escalating this. We’ve sent an invite to chat.
This message was authored by: Addie15
Update-We are closing this session now but if there is anything else in the future we can help you with, please do not hesitate to reach out. Thanks.
This message was authored by: JamboJJ
Hi @Chodley @Addie15 @Mr+Flibbles+86  I'm having the same issue, what was the resolution please? Thank
No idea. The chat seems to have been closed with no conclusion. Have escalated for you.
