4
This discussion topic has been answered Discussion topic: Red button match choice
This message was authored by: Gilky
My match choice red button doesn't work.can anybody help
Re: Red button match choice
Hi @Gilky
If you are referring to Hull vs West Brom on Channel 403 the red button is not shown
Edit
Just tried it again and it is there.
You are not using an early touch remote are you ?
Hi @Gilky
Edit
Avatar for Gilky
It does on main event.its meant to show Dortmund I believe
Avatar for Gilky
I think I have a fault I will need to contact sky my remote is the latest version
Hi @Gilky
Yes it's also on Main Event as well.
You have to go left on the top Hull vs West Brom tile once you get the split screen.
The Dortmund tile is hidden
Answered - Go to Answer
