Discussion topic: Recording not playing back
Message posted on 03 Jul 2025 04:53 PM
It's been some time now that my recordings stop playing back midway through or pause and I have to turn off the box and restart it every time. I can understand it happening once but not every time a play a recording, and also another thing is that if my box has been on standby and I try to turn it on via remote it doesn't come on I have to turn it off at the mains and turn I'd back on for it to start functioning again
Message posted on 03 Jul 2025 05:02 PM
Re: Recording not playing back
