Discussion topic: Remote
Message posted on 16 May 2025 07:32 PM
Remote
My sky q mini box remote was broken have had a replacement sent but wont connect any help would be appreciated very stressed
Message posted on 16 May 2025 07:38 PM
Re: Remote
May I suggest you try a reset of your new remote:
Press & Hold the 7 & 9 until the remote's light (red LED above the SKY logo button) flashes 4 times
Then press 1 & 3 together to go through to re-pair with the box and your TV - make sure it has line of sight of the box as until it is paired it uses Infrared
https://www.sky.com/help/diagnostics/sky-q-remotes/setting-up-remote
Message posted on 03 Jul 2025 02:15 PM
Re: Remote
My sky Q main box remote is broken was sent a mini box remote doesn't work with main box
Message posted on 03 Jul 2025 02:18 PM - last edited: 03 Jul 2025 02:18 PM
Re: Remote
Re: Remote
There is no different remote for a mini box. All currently provided remotes are the same.
Message posted on 03 Jul 2025 04:47 PM
Re: Remote
@Tate20 If the reote you had was a touch remote these wetre discontinued around 2019 ish all remotes are now the same as @nigea99 and @Daniel0210 have said
You will need to re-pair the remote to work with your box and TV the link to do this is in @nigea99 post above
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
