Discussion topic: Record button doesnt work
This message was authored by: Roger55
Your email to reset password hasnt come through
Re: Record button doesnt work
@Roger55
We are fellow customers on here so you’re not contacting Sky Customer Services by posting on the forum.
Avatar for Roger55
Level 0 icon
When i press record it comes up red but then says this programme cannot be recorded this is on every channel i cannot even delete recording programmes
@Roger55
Try a reboot of the main Sky Q box, then once that’s back up and running do the same with any mini boxes if necessary-
~ press the :lia_house: button
Avatar for Roger55
Level 0 icon
Done that
Hi @Roger55
After this If you cannot access your recordings or make new recordings then you may have a hard drive issue
https://www.sky.com/help/articles/sky-q-hard-disk-error-messages
Also if the box you are replacing is a 2TB there are two versions of power supply. One has a standard C7 (figure of eight) power lead socket in the back of the Q box. The other has a separate power supply. Although this still has the C7 power lead into the power supply there is a multi pin Din power socket in the Q box for connecting the power supply. Make sure that the replacement box has the power supply included if the Q box has the orange coded multi pin din socket in the back of the Q box.
