Discussion topic: Mini boxes stopped working
This message was authored by: Msp1978
Since we renewed oir contract with Sky our mini boxes have stopped working. Please can you turn them back on again? Thanks
Re: Mini boxes stopped working
@Msp1978
We can't turn anything on. We are fellow customers on here so you’re not contacting Sky Customer Services by posting on the forum. Did you make any changes to your subscription when renewing?
Hi @Msp1978
Check in your Q box  menu.
Home - Settings - Status.
Watch on Sky Q Mini box should be ticked.
Even if it is,   select Reactivate on the right to refresh.
Then:-
Reboot the minis as above.
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box. If you do this make sure you press the Sky router WPS button and not the router reset button. If you get the first mini connected then for other minis use WPS on the nearest Q device (main Q box or Sky Router if on Sky Broadband or previously connected mini).
