Discussion topic: Re booting
This message was authored by: HooliganZed
Re booting
Having problems changing channels and volume or getting on Home Screen and more or less anything that needs the remote.
It works fine after I reboot it, which is getting more regular. It's now got to a weekly issue.
Re: Re booting
@HooliganZed You could try resetting the settings in the Q boxes hidden menu.
To enter the hidden menu press the home button and scroll down to settings but do not select settings.
With settings highlighted press 0 0 1 then select
Only Carry out the first Reset being Reset Settings as the others will wipe all recordings.
After the reset you will have to re-pair your remote assuming you are using a bluetooth remote by pressing 1 and 3 together on the remote
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
