Discussion topic: MY SKY Q BOX APP PROBLEMS
Message posted on 05 Jun 2025 10:50 AM
All my apps causes the SKY Q box to switch of the box and light indicator show red. This happening multiple times every time I watch any of the apps programmes.
I need swift help or have to switch peovider.
Message posted on 05 Jun 2025 04:55 PM
Re: MY SKY Q BOX APP PROBLEMS
@SKYQBOX1 You could try resetting the settings in the Q boxes hidden menu.
To enter the hidden menu press the home button and scroll down to settings but do not select settings.
With settings highlighted press 0 0 1 then select
Only Carry out the first Reset being Reset Settings as the others will wipe all recordings.
After the reset you will have to re-pair your remote assuming you are using a bluetooth remote by pressing 1 and 3 together on the remote
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
