Discussion topic: Re: Sky
Message posted on 10 Aug 2023 11:22 AM
Re: Sky
I'm using communal WiFi. Landlord has sky q. Now if I plug my q box in as it's on same network it stops his working saying maximum number of devices So I have to disconnect my box. If I swap to a sky stream puck will this work or will it still say maximum number of devices?
Message posted on 10 Aug 2023 11:27 AM - last edited: 10 Aug 2023 11:29 AM
Re: Sky
@hifiman2007 You really need to have your own broadband setup, Stream may or may not work depending on speed etc, but given the fact they have Sky Q connected may cause issues.
Message posted on 10 Aug 2023 11:30 AM
Re: Sky
Cheers. I'll stick with q. Don't pay for my broad band so no advantage going for slightly cheaper stream then get hit with a broadband bill I never had before!
Message posted on 10 Aug 2023 01:06 PM - last edited: 10 Aug 2023 01:06 PM
Re: Sky
@hifiman2007 problem is that Sky have said before that using 2 main Q boxes on the same broadband connection can cause problems and it's not advisable
but there is no evidence that Sky Stream would be any better
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Message posted on 10 Aug 2023 01:10 PM
Re: Sky
yup. But the q box operates without need for WiFi. And I can at times connect it and download stuff when I know it won't affect landlords q. Stream requires a permanent WiFi connection so a big potential disadvantage.
