Discussion topic: Re: Lost ITV 1...
This message was authored by: Glenn71
Re: Lost ITV 1...
Hi, I have exactly the same problem, I can see ITV +1 but not ITV 1, did u find a solution?
Re: Lost ITV 1...
What are your Signal Strengths/Qualities? Take a look at the link below:
See question Q11 in my Sky Plus F⋅A⋅Q
Avatar for Glenn71
Re: Lost ITV 1...
Thanks, I'll have a look in the morning
Avatar for Glenn71
Re: Lost ITV 1...
hi , it says I currently have good satellite signal for my sky service, when I go To more info it says
sataelite signal -locked
signal strength-10
signal quality - 90
LNB type - wideband
Is this ok? It's only the one channel I can't see,
thanks in advance
Re: Lost ITV 1...
signal strength-10
signal quality - 90
LNB type - wideband
thanks in advance
The strength is bad 😞 also you only included 1 strength/quality there should be two for a standard Sky+ install
Avatar for Glenn71
Re: Lost ITV 1...
 hi, it's on sky Q not sure if that makes a difference these are screen shots, thanks
Re: Lost ITV 1...
@Glenn71
I have moved your posts to the Sky Q forum on here for you as you were posting in an old topic that was related to a similar issue to so with a Sky+ box.
Re: Lost ITV 1...
You posted in the SKY+ forum so any replies will assume you have SKY+, posting in the wrong forums confuses people any you will get answers that will mostly not help 😞
Your posts seem to have been moved to the correct forum so you should now be in better hands 🙂
Avatar for Glenn71
Re: Lost ITV 1...
Thank you Annie, it seems strange that on one screen it says I have good signal then the next say signal strength 10? Like I say, only one channel is affected, ITVhd
Re: Lost ITV 1...
This is most likely a dish alignment fault, it can affect just a few channels. Depending on which ITV region you're in there may be some other channels affected that you just haven't noticed yet.
Avatar for Glenn71
Re: Lost ITV 1...
Ok, thanks for ur reply, I take it I'll need a satellite engineer to take a look, any idea how much they charge for this?
thanks
