11
This discussion topic has been answered Discussion topic: Quest HD no tv guide
This message was authored by: SpencerLincoln
Rebooted many times, guide has completely run out for quest HD, all others ok.
Avatar for SpencerLincoln
This message was authored by: SpencerLincoln Answer
Re: Quest HD no tv guide
Finally been updated after 6 days without guide.... time to catch up on missed new series linked content 😂
This message was authored by: mr.tickle
Hmm, it's fine for me.
I do not have a sig other than this message. SkyQ.
Enjoying HDR with 4k Blu-Ray, Amazon, YouTube and gaming since 2016.
This message was authored by: JonAnderton
Same issue, Sky HD guide just saying This is Quest HD in 30 min blocks. Unable to select programmes to record
Hi @JonAnderton   Sky+HD? Quest HD EPG fully occupied on Sky Q (this community).
I think it may be the Irish version that is affected. It's fine in the UK.
It's the Sky+HD programme guide
And just to confirm are you in the UK?
The UK version of Quest has the correct EPG data, but the Irish version has been missing EPG data since 16th September.
It'son the Irish EPG
This message was authored by: Phpotno7
Still not showing any programmes and not picking up to record any ideas how to fix
Yes I'm in Ireland looks like it's just us here affected then
@SpencerLincoln @Phpotno7 @Phpotno7 If it's still happening you could report it to viewer relations although not sure if they can help if its only in Ireland that the problem is but woth a try you can contact them at [email protected]
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Answered - Go to Answer
