Discussion topic: Q network problems
This message was authored by: lizzy275
Q network problems
We recently changed our network provider and router, although the signal is excellent our SkyQ boxes, mini boxes, keep disconnecting from the Q network, NOT the internet. One of them will not connect to the Q network at all
Re: Q network problems
As you have changed router you will need to reset the connection between your main Sky Q box and the mini boxes.
Follow the instructions here to reset your network connection on the mini boxes one at a time:
https://www.sky.com/help/articles/sky-q-permanent-connectivity-problems-no-booster
If you have a partial success with connections but they keep dropping, it's can also be because the new router network is too close to the frequency the 5ghz mesh the main Q box is generating and the mini boxes connect to.
You can adjust the 5ghz settings in the router to move it away from the channel 36 80 Mhz channel that Q uses, or change the Q box itself in the installer menu.
Was my post helpful or informative to you? Please give it a thumbs up/like.
If my post has solved your problem, great! Please click on "Mark as Answer" under it and share the love!
