Discussion topic: Netflix
Message posted on 12 May 2025 04:17 PM
Netflix
how can you connect Netflix to iPad if it's through your sky account
Message posted on 12 May 2025 04:30 PM
Re: Netflix
Hi @Laurapeter
Your Sky Netflix will work on any device that has the Netflix App. You just to download the Netflix App onto your device
You just to sign in with your Sky Netflix log in.
Message posted on 12 May 2025 04:50 PM
Re: Netflix
I don't have a login for it because it's paid for in our sky bill
Message posted on 12 May 2025 05:05 PM
Re: Netflix
Hi @Laurapeter It sounds like you have not activated your Netflix account. This will give you your user name and password to sign on to any device. https://www.sky.com/help/articles/apps-on-sky-q-and-glass-netflix
Message posted on 12 May 2025 05:20 PM
Re: Netflix
@Laurapeter If you can watch it on your Q box then at sometime you would have set up a username and password. I get mine through Sky and had to create a username and password
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
