Discussion topic: Q box software won’t update
This message was authored by: rachel60
Re: Q box software update running but unable to complete
Hi @rachel60   How do you know that a software update is running?
Re: Q box software won’t update
@rachel60 wrote:
Hi @rachel60
Home - settings - System info - Software
Latest Version is Q230.000..............
However bear if mind that when you select Setup (in Setting - System info - Software version) the message received will always be update this box with the latest software even if the box is already on the latest version.
Updating when already on the latest version achieves nothing and the box software is not refreshed.
All Q boxes and minis should be on the same software version.
@oldfella wrote:
@rachel60 wrote:
Hi @rachel60
And yes, the fact it doesn't check the latest version online and tell you no update is needed if they match is ridiculous but here we are.
