Discussion topic: Cnt get my sky q connected to my new 4k tv
Message posted on 26 Nov 2023 10:32 PM
I got a new 4k tv and my sky q box isn't working on it. It comes up on the screen " weak or no signal". I have checked all connections and the are all correct
Message posted on 26 Nov 2023 11:48 PM
Re: Cnt get my sky q connected to my new 4k tv
That sounds like it's a message from your TV trying to use freeview
Is it set to use an HDMI source?
Message posted on 27 Nov 2023 02:52 PM
How do u do that?
Message posted on 27 Nov 2023 03:09 PM
You'd use the television remote control to change the input to the HDMI port which the Q box is connected to.
Message posted on 27 Nov 2023 03:11 PM
@Stewarth79 wrote:How do u do that?
With the remote control supplied with the TV normally. Have a read of the TV's manual.
Alternatively, hitting the Sky button on the Sky remote may send a CEC signal so the TV automatically switches.
Message posted on 27 Nov 2023 03:22 PM
As mentioned by the others above, you press the source selection button on the TV remote to cycle through the inputs. Usually looks like a TV screen with an arrow pointing into it from the left.
Let it stop on each one for 5 seconds to give it a chance to sync any incoming signal.
Message posted on 27 Nov 2023 04:26 PM
Doesn't the Sky Q remote have the ability to do this like the Sky+HD remote does?
Sky Community Forum SuperUser
Former Sky+HD Beta Tester
Message posted on 27 Nov 2023 04:29 PM - last edited: 27 Nov 2023 04:30 PM
Sort of but I would do it with the TV remote first to make sure it was all working and not being screwed up by a bad sky remote config.
Get a picture first and then start worrying about optimising the number of remotes.
