27 Nov 2023 02:51 PM
SkyQ box keeps losing network and when we reinstall it is finding our old router name or a neighbours and the Apps won't connect.
We contacted BT our broadband provider and they said it was the sky box at fault
27 Nov 2023 03:10 PM
@HD65 wrote:We contacted BT our broadband provider and they said it was the sky box at fault
Yes, other providers do like pointing the finger elsewhere.
However, as a non-Sky ISP the box will only connect over 2.4GHz. It's usually best to set up a dedicated SSID on the BT router (if it's capable). Ensure any smart modes and steering are disabled.
Perform a network reset on the Q box and connect using the WPS button if you can.
27 Nov 2023 03:29 PM
Posted by a Superuser, not a Sky employee. Find out moredo it with the minis and any boosters switched off and see if you then get your current router SSID showing
