Discussion topic: Programme not available when it should be
Message posted on 31 May 2025 11:19 AM
Hi. I've just tried watching And Just like that S3:1. It's coming up with message no longer available but it's just aired and the info says it's available until 29/6. Any ideas?
Message posted on 31 May 2025 11:24 AM
Re: Programme not available when it should be
Message posted on 31 May 2025 11:38 AM
What info do you need? It's in Sky Comedy. Aired yesterday at 2am I think
Message posted on 31 May 2025 11:43 AM
Message posted on 31 May 2025 11:50 AM
I am getting the same message 'no longer available '.
Message posted on 31 May 2025 11:51 AM
Series 3 ep 1
Message posted on 31 May 2025 11:54 AM
Thanks. Can you see the detail on the attached picture?
Message posted on 31 May 2025 12:04 PM
Hi @ggbeeb What format, UHD HDR, UHD, HD or SD.
Message posted on 31 May 2025 12:06 PM
Hi @ggbeeb All not available here, you should contact viewer relations by emailing [email protected]
Message posted on 31 May 2025 12:09 PM
Message posted on 31 May 2025 12:11 PM
Just tried playing this S3 ep 1 episode on my Sky Stream.
The episode plays, but it's having trouble randomly now and again using skip fast forward.
Does seem something is amiss with the episode.
Would suggest for those having the problem with this episode best to get it checked and resolved by Sky by sending an email to the Sky Viewer relations team to report it;
[email protected]
They do respond to emails with any updates for your queries or problems.
Message posted on 31 May 2025 01:04 PM
Thanks everyone. Have tried other formats. Will contact Sky via email as suggested
Message posted on 31 May 2025 06:39 PM
Same here
Message posted on 31 May 2025 09:20 PM
Working now. Not sure if emailing did it or it just got sorted.
