Discussion topic: Minibox
Message posted on 31 May 2025 08:24 PM
Minibox
One of my mini boxes will not connect to my sky q box
Message posted on 31 May 2025 08:25 PM
Re: Minibox
Hi @Japper1
Reboot the minis as above.
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box. If you do this make sure you press the Sky router WPS button and not the router reset button. If you have the new Sky Max router then you need to connect the WPS to the main Q box.
If you get the first mini connected then for other minis use WPS on the nearest Q device (main Q box or Sky Router (not Sky Max) if on Sky Broadband or previously connected mini).
