Discussion topic: Problem with satellite signal for some channels
This message was authored by: LisaB231
Hello, I am receiving the error message 'channel is currently affected by a problem with satellite signal'.  This is being received on only some  channels - not all of them.
I have switched off from the mains and re-started but am still getting the same error message - any ideas on I need to do?
thanks
This message was authored by: Invisiblename
Re: Problem with satellite signal for some channels
thanks
Sounds like a dish alignment problem, which would require an engineer to sort.  One thing you can check before resorting to booking an engineer (and not likely to see one until the New Year) is to check that the dish input connectors on the back of your Sky Q box are still finger tight.
I am just another Sky customer!
@LisaB231
Look at the troubleshooting on this link
It may then give you the opportunity to arrange an engineer to check the alignment of your dish (it’s not something that will necessarily be visible to the naked eye). If you’re on a communal dish you may initially need to liaise with your landlord or building management company.
▪️I AM NOT A SKY EMPLOYEE ▪️
