Discussion topic: Problem finding sky q box on network
This message was authored by: Rebecca272
Tried everything and still not connecting but working fine up until an hour ago
This message was authored by: Ecosse
Re: Problem finding sky q box on network
I'd suggest fully rebooting both the router and the Sky Q main box.
Unplug both of them, same time, from the wall for at least 30 seconds.
Plug back in the router only, get it up and running, and run a speed test on your mobile. Now plug back in the Sky Q box, go to settings, and reset the network settings section. Then scan for your router, add in your password, and hopefully, you're back up and running.
Good luck.
Samsung UE49MU7070XX - Samsung MS550 Soundbar+ with 9000S Rears
Sky Q 2Tb + 3 Minis - BT Full Fibre 900
This message was authored by: Adubi
Just got a new contract and my second box not working ErrorMR104
Problem finding my sky Q box on the network
@Adubi Have you tried rebooting your main Q box ie
then
reboot the mini box
This message was authored by: kadie+louise
I have this message daily I wish to resolve please help
On a mini?
Yp every night error mr104
Does the Q lose its internet connection too?
Sometimes but not like it us to before I got booster
I meant specifically when the mini error happens.
After 12am daily, probably after or waist update is happening which is a pest as well, all i want is to go to bed and watch TV but no I have to run down turn on qbox wait for that to do what it's doing then go back to upstairs mini box to sort out from then as well, sometimes it losses both internet and losses qbox but most times it's lossing qbox, I have had a new qbox and new mini box and had phoneline and  broadband box replaced and added internet booster off sky this issue still happens
When you say after midnight - are we talking as late as 2 when it does its daily refresh cycle?
I go bed at 12, 1, 2, 3am mini box is like this at these times until I come down to qbox and turn on,  as the Q light is blue on main qbox but after a couple of seconds it comes on and sometime the mini box is then working or sometimes I have to reactivate
Hmm
at 12 that's odd. At 3 it's expected.
Try setting the Eco mode to Active.
