Discussion topic: Ppv happened but nobody ordered it
Message posted on 31 Mar 2024 01:03 PM
A ppv event has appeared on my account for a TNT wrestling match that nobody in my household ordered. Nobody apart from me knows the pin. I hate wrestling and certainly did not order this. A sky rep said that the pin has to be entered 3 times and basically called me a liar fir saying that I did not order it. So as far as I can see there is no way to change their minds....help please
Message posted on 31 Mar 2024 01:16 PM
Re: Ppv happened but nobody ordered it
I don't order PPV either so don't know how many times the pin needs entering. It might be wise to change the pin number anyway just in case.
Message posted on 31 Mar 2024 03:51 PM
Have you checked that the pin is indeed turned on for purchases?
See https://www.sky.com/help/articles/managing-parental-settings
As per this
Turning PIN on purchase on or off
Your Sky box is set up to ask for your PIN before you buy or rent any shows, movies or PPV events via the Sky Store or Box Office to keep your account secure.
If you are looking to rent any movies or PPV events via the Sky Store or Box Office, you can turn this off if you wish.
To do this:
1. Press Home on your Sky Q remote and select Settings, then Parental.
2. Enter your Sky TV PIN.
3. Select Family, then PIN on purchaseOff
4. Select Off to remove the need for a PIN for rentals or Box Office, or On to ask for a PIN before a movie can be rented or an event booked.
ROI sky Q Customer.
Message posted on 31 Mar 2024 04:45 PM
Yes I know about that thanks but the point is that there are only 2 of us in the house, and only I know the pin. I did not order a box office as stated. In fact I have never done so.
Message posted on 31 Mar 2024 05:53 PM
Hi @matri25x
All you can do is raise a formal complaint https://www.sky.com/help/articles/how-to-make-a-complaint
You could also try viewer relations by emailing viewerR@sky.uk
Message posted on 31 Mar 2024 06:18 PM
Thanks for the suggestions, I will certainly follow them up. I am expecting a call from Retentions who said a manager will call.
Cheers
Message posted on 31 Mar 2024 06:34 PM
A pin doesn't require being entered 3 times . Everytime I've ordered a PPV I only enter it once just to confirm the order.
Sky Glass TV Gen 2. 55” Volcanic Black
1x Sky Stream Puck
Sky Ultimate TV & Netflix Premium
Sky Sports Complete Pack
Sky Cinema
TNT Sports
Sky Ultra HD & Dolby Atmos
Sky Whole Home
Ad Skipping Pack
MUTV
Virgin Media Broadband Gig1
Message posted on 31 Mar 2024 07:24 PM
@matri25x wrote:A ppv event has appeared on my account for a TNT wrestling match that nobody in my household ordered. Nobody apart from me knows the pin. I hate wrestling and certainly did not order this. A sky rep said that the pin has to be entered 3 times and basically called me a liar fir saying that I did not order it. So as far as I can see there is no way to change their minds....help please
You only need to enter the pin once. Have you ever ordered a PPV event on TNT previously as when I used to work for them the charge could be very late in arriving (months and months later in fact). Do you know what the event was exactly? Sky (or TNT perhaps) will be able to tell you exactly when it was ordered.
Message posted on 31 Mar 2024 07:56 PM
If ordered via the Box then the event has to be watched (even for a second) for it then to charge.
There are other ways to order the event so are you sure it was via the remote?
SkyQ Silver bundle (V2 2TB with UHD/HDR + two minis) in Sky region #71 (Oxford) using VirginMedia Gig1 Fibre (1.2Gbps/100Mbps).
Message posted on 31 Mar 2024 08:51 PM
1 I have never order a box office event with Sky or Tnt
2 not being aware of this I certainly did not watch it
I wonder how Data Security stands up in this if someone else has ordered this and somehow it has ended up on my account.
Message posted on 31 Mar 2024 09:17 PM
@matri25x wrote:2 answers
TNT bought out BT Sports PPV awhile back so if it was an older order it would have been under BT, not Sky (even if on your Sky bill).
Data security has nothing to do with it and no one can order it and it end up on your account. I would hazard a guess someone in your houshold ordered it without telling you.
Message posted on 31 Mar 2024 09:19 PM
@matri25x the Discovery+ app on a mobile device also allows you to order PPV content for TNT Sport
Message posted on 31 Mar 2024 09:24 PM
Then there would be an onus on you to prove such.
ROI sky Q Customer.
Message posted on 31 Mar 2024 09:27 PM
I reiterate there are only 2 in the household ans neither of us has ordered this. I'll check my account weekly from now on. Meanwhile I have a formal complaint registered as recommended earlier. Will post any relevant updates.
Message posted on 01 Apr 2024 01:17 PM
Do you have any pets? I'm wondering if by some strange chance a pet has stood on the remote & somehow changed the channel to ppv & entered the pin.
I don’t work for Sky.
If I have helped then please leave a like.
