Discussion topic: Power cable
This message was authored by: Foxred
Power cable
I had a new box delivered today after my old box crashed with the outage issue. The delivery guy swapped the remote and when I asked about the cables he said they were the same. But they're not! So I have a new sky box with the wrong power cable!! When I rang to say there was no cable , I was told an engineer can deliver a cable in a month or I can go and buy one! Not good  enough cinsidering the amount I pay each month. Now I have no power cable and no resolution! Really poor service. The delivery courier should have been told to swap all cables as well as the box.
Re: Power cable
Hi @Foxred   Which power cable do you require? Is it a separate power brick with a round plug, or a C7 figure of eight plug. I hope you remembered to keep your viewing card.
Re: Power cable
@Foxred this happens all the time if its the seperate power brick cable that is missing with the multipin connection normally Sky will send out another swap box to you so maybe worth while contacting them again if its a normal figure of 8/c7 cable then you can purchase them from most electronic hardware stores if you can't/dont want to wait for an engineer
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Avatar for Foxred
Re: Power cable
It's the round one .
Re: Power cable
Not sure why you were told you can buy one, they're pretty proprietary. The figure 8 one is just standard and easy/cheap to acquire.
It's deeply annoying that Sky don't make sure DPD don't screw this up.
This message was authored by: Jack-son
Re: Power cable
I'm facing the exact same problem! Called sky, they said they'd send a new box out. I've been waiting over 2 weeks now & still no power cable has arrived!!!
Re: Power cable
They won't send a power cable on its own. I would call them and ask where the replacement box is at
Re: Power cable
yes that's what they said, they'd have to send out a new box. Phoned last week as it still hadn't arrived after a week and told it would arrive within 5 days, which should have been Thursday. Over 2 weeks has gone since they took the old box away & still no new box has been sent.
This message was authored by: Tom-W19
Re: Power cable
Hi @Jack-son
Your post has been escalated to our Community Messaging team who will invite you to a private chat shortly and help you with this.
Just look out for the chat bubble to start the conversation. The invite will automatically close if not responded to within 48 hours.
Here's more information on how Community Messaging works - https://community.sky.com/t5/Did-you-know/Escalating-a-post-to-a-Sky-expert/ba-p/3711147
Tom
